Disable PTP on a particular clock instance, or on a specified vlan port (clock port) of the clock instance.
| boundary | Boundary clock instance. |
| ordinary | Ordinary clock instance. |
| vlan_name | Vlan name. |
PTP is disabled by default on a clock instance.
Use this command to disable PTP on a clock instance.
The following example disables the ordinary clock:
# disable network-clock ptp ordinary
The following example disables the clock port lpbk-transit on the boundary clock:
# disable network-clock ptp boundary vlan lpbk-transit
This command was first available in ExtremeXOS 15.1.
This command is available on 7520-48Y and 7720 platforms.
PTP commands can be used only with the Premier license pack.
